[gdal-dev] Dateline gap
Jerl Simpson jsimpson at wxtrends.com
Tue Apr 12 15:59:08 EDT 2011
Hello:
I stopped by the #gdal channel on IRC to ask this question.  Thank you
for the help provided there.  I thought it might be better if I asked
a question here so I can better explain what's going on in one spot
and not flood the channel.
I understand this is a pixel center vs pixel edge issue.
My ultimate goal is to get from a netCDF file to a google map overlay contour.
The general steps I've taken, which work all the way up to about
178.29 then it just cuts off.
netCDF -> color-relief PNG using "gdaldem color-relief ...  "
PNG -> Geocoded PNG using "gdal_translate -a_srs EPSG:4326 -outsize
4096 4096 -a_ullr -180.25 90.25 180.25 -90.25" on the PNG (Have also
tried this with just "-180 90 180 -90"
PNG -> tiles using "gdal2tiles.py -s EPSG:4326 -z 0 -n -w google" on
the Geocoded PNG
I guess first question, is my methodology sound?  Maybe there's a
better way/tool to approach the problem.
Following is the output from gdalinfo, other than that, what
information might I be able to provide that could help?
Thank you,
Jerl
gdalinfo for the source netcdf: (My apologies, I'm not certain what is
relevant so I'm including most everything.)
Driver: netCDF/Network Common Data Format
Files: test.nc
Size is 721, 361
Coordinate System is `'
Origin = (-180.250000000000000,90.250000000000000)
Pixel Size = (0.500000000000000,-0.500000000000000)
Metadata:
  NC_GLOBAL#Conventions=CF-1.0
  NC_GLOBAL#cdm_data_type=GRID
  NC_GLOBAL#file_format=GEMPAK
  NC_GLOBAL#location=test.grd
  NC_GLOBAL#history=Direct read of GEMPAK into NetCDF-Java 4.0 API
  NC_GLOBAL#_CoordinateModelRunDate=2011-04-12T00:00:00Z
  UVIN_NONE#long_name=testdata
  UVIN_NONE#units=
  UVIN_NONE#missing_value=-9.999000e+03
  UVIN_NONE#VectorComponentFlag=gridRelative
  time#long_name=forecast time
  time#units=minute since 2011-04-12T00:00:00Z
  time#_CoordinateAxisType=Time
  lat#units=degrees_north
  lat#long_name=latitude coordinate
  lat#standard_name=latitude
  lat#grid_spacing=0.5 degrees_north
  lat#_CoordinateAxisType=Lat
  lon#units=degrees_east
  lon#long_name=longitude coordinate
  lon#standard_name=longitude
  lon#grid_spacing=0.5 degrees_east
  lon#_CoordinateAxisType=Lon
Corner Coordinates:
Upper Left  (-180.2500000,  90.2500000)
Lower Left  (-180.2500000, -90.2500000)
Upper Right ( 180.2500000,  90.2500000)
Lower Right ( 180.2500000, -90.2500000)
Center      (   0.0000000,   0.0000000)
gdalinfo of geocoded PNG:
Driver: PNG/Portable Network Graphics
Files: testWorld.png
       testWorld.png.aux.xml
Size is 4096, 4096
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.01745329251994328,
        AUTHORITY["EPSG","9122"]],
    AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.087890625000000,-0.043945312500000)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left  (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
Upper Right ( 180.0000000,  90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
Center      (   0.0000000,   0.0000000) (  0d 0'0.01"E,  0d 0'0.01"N)
Band 1 Block=4096x1 Type=Byte, ColorInterp=Red
  Mask Flags: PER_DATASET ALPHA
Band 2 Block=4096x1 Type=Byte, ColorInterp=Green
Band 3 Block=4096x1 Type=Byte, ColorInterp=Blue
Band 4 Block=4096x1 Type=Byte, ColorInterp=Alpha
This communication is privileged and may contain confidential
information.  It's intended only for the use of the person or entity
named above. If you are not the intended recipient, do not distribute
or copy this communication. If you have received this communication in
error, please notify the sender immediately and return the original to
the email address above. © Copyright 2011 Weather Trends
International, Inc.
