[gdal-dev] Dateline gap
Jerl Simpson jsimpson at wxtrends.com
Tue Apr 12 20:31:35 EDT 2011
Thanks for the GMT suggestions. I've never used it, I'll try it out.
Thanks!!
Typed with thumbs...
On Apr 12, 2011 7:24 PM, "Joaquim Luis" <jluis at ualg.pt> wrote:
> Jerl,
> I would do that with GMT. By using ps2raster you can convert any GMT
> figure (in geogs of course) into KML, and GMT has excellent care of date
> line transition issues.
> Joaquim
>> Hello:
>> I stopped by the #gdal channel on IRC to ask this question. Thank you
>> for the help provided there. I thought it might be better if I asked
>> a question here so I can better explain what's going on in one spot
>> and not flood the channel.
>> I understand this is a pixel center vs pixel edge issue.
>> My ultimate goal is to get from a netCDF file to a google map overlay
contour.
>> The general steps I've taken, which work all the way up to about
>> 178.29 then it just cuts off.
>> netCDF -> color-relief PNG using "gdaldem color-relief ... "
>> PNG -> Geocoded PNG using "gdal_translate -a_srs EPSG:4326 -outsize
>> 4096 4096 -a_ullr -180.25 90.25 180.25 -90.25" on the PNG (Have also
>> tried this with just "-180 90 180 -90"
>> PNG -> tiles using "gdal2tiles.py -s EPSG:4326 -z 0 -n -w google" on
>> the Geocoded PNG
>> I guess first question, is my methodology sound? Maybe there's a
>> better way/tool to approach the problem.
>> Following is the output from gdalinfo, other than that, what
>> information might I be able to provide that could help?
>> Thank you,
>> Jerl
>> gdalinfo for the source netcdf: (My apologies, I'm not certain what is
>> relevant so I'm including most everything.)
>> Driver: netCDF/Network Common Data Format
>> Files: test.nc
>> Size is 721, 361
>> Coordinate System is `'
>> Origin = (-180.250000000000000,90.250000000000000)
>> Pixel Size = (0.500000000000000,-0.500000000000000)
>> Metadata:
>> NC_GLOBAL#Conventions=CF-1.0
>> NC_GLOBAL#cdm_data_type=GRID
>> NC_GLOBAL#file_format=GEMPAK
>> NC_GLOBAL#location=test.grd
>> NC_GLOBAL#history=Direct read of GEMPAK into NetCDF-Java 4.0 API
>> NC_GLOBAL#_CoordinateModelRunDate=2011-04-12T00:00:00Z
>> UVIN_NONE#long_name=testdata
>> UVIN_NONE#units=
>> UVIN_NONE#missing_value=-9.999000e+03
>> UVIN_NONE#VectorComponentFlag=gridRelative
>> time#long_name=forecast time
>> time#units=minute since 2011-04-12T00:00:00Z
>> time#_CoordinateAxisType=Time
>> lat#units=degrees_north
>> lat#long_name=latitude coordinate
>> lat#standard_name=latitude
>> lat#grid_spacing=0.5 degrees_north
>> lat#_CoordinateAxisType=Lat
>> lon#units=degrees_east
>> lon#long_name=longitude coordinate
>> lon#standard_name=longitude
>> lon#grid_spacing=0.5 degrees_east
>> lon#_CoordinateAxisType=Lon
>> Corner Coordinates:
>> Upper Left (-180.2500000, 90.2500000)
>> Lower Left (-180.2500000, -90.2500000)
>> Upper Right ( 180.2500000, 90.2500000)
>> Lower Right ( 180.2500000, -90.2500000)
>> Center ( 0.0000000, 0.0000000)
>> gdalinfo of geocoded PNG:
>> Driver: PNG/Portable Network Graphics
>> Files: testWorld.png
>> testWorld.png.aux.xml
>> Size is 4096, 4096
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.01745329251994328,
>> AUTHORITY["EPSG","9122"]],
>> AUTHORITY["EPSG","4326"]]
>> Origin = (-180.000000000000000,90.000000000000000)
>> Pixel Size = (0.087890625000000,-0.043945312500000)
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
>> Lower Left (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
>> Upper Right ( 180.0000000, 90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
>> Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
>> Center ( 0.0000000, 0.0000000) ( 0d 0'0.01"E, 0d 0'0.01"N)
>> Band 1 Block=4096x1 Type=Byte, ColorInterp=Red
>> Mask Flags: PER_DATASET ALPHA
>> Band 2 Block=4096x1 Type=Byte, ColorInterp=Green
>> Band 3 Block=4096x1 Type=Byte, ColorInterp=Blue
>> Band 4 Block=4096x1 Type=Byte, ColorInterp=Alpha
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110412/abc4607d/attachment.html
