[gdal-dev] GDAL Native Libraries 1.4.5b for Linux64 not available
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Apr 13 05:02:10 EDT 2011
The site also shows the GDAL 1.7.3 version in the dependencies and the file
exists. Perhaps imageio-ext 1.0.8 does support gdal1.7.3
On Wed, Apr 13, 2011 at 1:59 PM, Andreas Oxenstierna <ao at t-kartor.se> wrote:
>  If I am interpreting the information correctly on
> http://docs.geoserver.org/latest/en/user/data/gdal.html
> GeoServer is using Image I/O-Ext 1.0.8 which is using GDAL 1.4.5, that is
> my reason.
> How can I get access to the file gdal1.4.5b-linux64-base.tar.gz<http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz>? I cannot download it from the link below with any tested browser, instead
> getting a message "The page you were looking for doesn't exist".
> Andreas
> Andreas,
> The file exists. However, the GDAL 1.4 branch is no longer supported. The
> latest stable version is 1.8 although 1.7 is also supported. Why don't you
> use the 1.7 version.
> On Wed, Apr 13, 2011 at 1:16 PM, Andreas Oxenstierna <ao at t-kartor.se>wrote:
>>  Need to include GDAL support for GeoServer 2.1 on Linux 64-bit. However,
>> it seems that the link to the native libraries on
>> is broken. Can I get the gdal1.4.5b-linux64-base.tar.gz from somewhere else
>> or do I need to build it from the source files?
>> Andreas Oxenstierna
>> T-Kartan Produkt AB
>> mobile: +46 733 206831
>> mailto: ao at t-kartor.sehttp://www.t-kartor.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> Andreas Oxenstierna
> T-Kartan Produkt AB
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/be71b0f7/attachment.html
