[gdal-dev] GDAL Native Libraries 1.4.5b for Linux64 not available
Andreas Oxenstierna ao at t-kartor.se
Wed Apr 13 06:40:06 EDT 2011
File downloaded, thanks a lot
Andreas
> Hi all,
> the ImageIO-Ext 1.0.8 uses GDAL 1.4.5.
> GDAL 1.7.3 is needed by ImageIO-Ext 1.1.x (which is not yet used by
> GeoServer 2.2.x... I'm still working on this, these days)
> About the broken link, I think there is some issue on the new site
> based on Kenai. Not sure why/how it has been broken since these files
> have been already downloaded several times. (It seems that several
> links now reports "not found")
> I have uploaded it again the file you are looking for. (I will check
> which files are now unavailable and then redeploy them if needed)
> Hope this helps.
> Regards,
> Daniele
> On Wed, Apr 13, 2011 at 11:02 AM, Chaitanya kumar CH <chaitanya.ch
> <http://chaitanya.ch>@gmail.com <http://gmail.com>> wrote:
>     The site also shows the GDAL 1.7.3 version in the dependencies and
>     the file exists. Perhaps imageio-ext 1.0.8 does support gdal1.7.3
>     On Wed, Apr 13, 2011 at 1:59 PM, Andreas Oxenstierna
>     <ao at t-kartor.se <mailto:ao at t-kartor.se>> wrote:
>         If I am interpreting the information correctly on
>         http://docs.geoserver.org/latest/en/user/data/gdal.html
>         GeoServer is using Image I/O-Ext 1.0.8 which is using GDAL
>         1.4.5, that is my reason.
>         How can I get access to the file
>         gdal1.4.5b-linux64-base.tar.gz
>         <http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz>
>         ? I cannot download it from the link below with any tested
>         browser, instead getting a message "The page you were looking
>         for doesn't exist".
>         Andreas
>>         Andreas,
>>         The file exists. However, the GDAL 1.4 branch is no longer
>>         supported. The latest stable version is 1.8 although 1.7 is
>>         also supported. Why don't you use the 1.7 version.
>>         On Wed, Apr 13, 2011 at 1:16 PM, Andreas Oxenstierna
>>             Need to include GDAL support for GeoServer 2.1 on Linux
>>             64-bit. However, it seems that the link to the native
>>             libraries
>>             onhttp://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz
>>             is broken. Can I get the gdal1.4.5b-linux64-base.tar.gz
>>             from somewhere else or do I need to build it from the
>>             source files?
>>             Andreas Oxenstierna
>>             T-Kartan Produkt AB
>>             mobile:+46 733 206831  <tel:%2B46%20733%20206831>
>>             mailto:ao at t-kartor.se  <mailto:ao at t-kartor.se>
>>             http://www.t-kartor.com
>>             _______________________________________________
>>             gdal-dev mailing list
>>             gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>             http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>         Best regards,
>>         Chaitanya kumar CH.
>>         /tʃaɪθənjə/ /kʊmɑr/
>>         +91-9494447584 <tel:%2B91-9494447584>
>>         17.2416N 80.1426E
>         Andreas Oxenstierna
>         T-Kartan Produkt AB
>     Best regards,
>     Chaitanya kumar CH.
>     /tʃaɪθənjə/ /kʊmɑr/
>     17.2416N 80.1426E
> Ing. Daniele Romagnoli
> GeoSolutions S.A.S.
> Software Engineer
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 962313
> mob:   +39 328 0559267
> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> http://geo-solutions.blogspot.com/
> http://www.youtube.com/user/GeoSolutionsIT
> http://it.linkedin.com/in/danieleromagnoli
Andreas Oxenstierna
T-Kartan Produkt AB
mobile: +46 733 206831
mailto: ao at t-kartor.se
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/5a3acb84/attachment.html
