[gdal-dev] Gamma parameter not set in proj4 string for RSO projections
Jürgen E. Fischer jef at norbit.de
Thu Apr 14 06:28:22 EDT 2011
Hi Even,
On Thu, 14. Apr 2011 at 09:51:54 +0200, Even Rouault wrote:
> I know they have updated very recently their srs.db to sync it with GDAL 1.8.0.
> Perhaps you should also update to the latest svn version of qgis ?
OSGeo4W has the qgis-dev package which is a nightly build of trunk.
But the sync was with PROJ and not with GDAL.  And I think that was wrong.
What's the process to update the SRS databases?  I found a README from Frank in
that it seems that geotiff is updated first,  gdal from that and from there
proj and postgis.
Not sure what or if the metacrs project adds to the picture...
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
