[gdal-dev] Re: Dateline gap
Jerl Simpson jsimpson at wxtrends.com
Thu Apr 14 09:41:01 EDT 2011
Does anyone on the GDAL team have any suggestions on how to do this?
Thank you,
Jerl
On Tue, Apr 12, 2011 at 2:59 PM, Jerl Simpson <jsimpson at wxtrends.com> wrote:
> Hello:
> I stopped by the #gdal channel on IRC to ask this question.  Thank you
> for the help provided there.  I thought it might be better if I asked
> a question here so I can better explain what's going on in one spot
> and not flood the channel.
> I understand this is a pixel center vs pixel edge issue.
> My ultimate goal is to get from a netCDF file to a google map overlay contour.
> The general steps I've taken, which work all the way up to about
> 178.29 then it just cuts off.
> netCDF -> color-relief PNG using "gdaldem color-relief ...  "
> PNG -> Geocoded PNG using "gdal_translate -a_srs EPSG:4326 -outsize
> 4096 4096 -a_ullr -180.25 90.25 180.25 -90.25" on the PNG (Have also
> tried this with just "-180 90 180 -90"
> PNG -> tiles using "gdal2tiles.py -s EPSG:4326 -z 0 -n -w google" on
> the Geocoded PNG
> I guess first question, is my methodology sound?  Maybe there's a
> better way/tool to approach the problem.
> Following is the output from gdalinfo, other than that, what
> information might I be able to provide that could help?
> Thank you,
> Jerl
> gdalinfo for the source netcdf: (My apologies, I'm not certain what is
> relevant so I'm including most everything.)
> Driver: netCDF/Network Common Data Format
> Files: test.nc
> Size is 721, 361
> Coordinate System is `'
> Origin = (-180.250000000000000,90.250000000000000)
> Pixel Size = (0.500000000000000,-0.500000000000000)
> Metadata:
>  NC_GLOBAL#Conventions=CF-1.0
>  NC_GLOBAL#cdm_data_type=GRID
>  NC_GLOBAL#file_format=GEMPAK
>  NC_GLOBAL#location=test.grd
>  NC_GLOBAL#history=Direct read of GEMPAK into NetCDF-Java 4.0 API
>  NC_GLOBAL#_CoordinateModelRunDate=2011-04-12T00:00:00Z
>  UVIN_NONE#long_name=testdata
>  UVIN_NONE#units=
>  UVIN_NONE#missing_value=-9.999000e+03
>  UVIN_NONE#VectorComponentFlag=gridRelative
>  time#long_name=forecast time
>  time#units=minute since 2011-04-12T00:00:00Z
>  time#_CoordinateAxisType=Time
>  lat#units=degrees_north
>  lat#long_name=latitude coordinate
>  lat#standard_name=latitude
>  lat#grid_spacing=0.5 degrees_north
>  lat#_CoordinateAxisType=Lat
>  lon#units=degrees_east
>  lon#long_name=longitude coordinate
>  lon#standard_name=longitude
>  lon#grid_spacing=0.5 degrees_east
>  lon#_CoordinateAxisType=Lon
> Corner Coordinates:
> Upper Left  (-180.2500000,  90.2500000)
> Lower Left  (-180.2500000, -90.2500000)
> Upper Right ( 180.2500000,  90.2500000)
> Lower Right ( 180.2500000, -90.2500000)
> Center      (   0.0000000,   0.0000000)
> gdalinfo of geocoded PNG:
> Driver: PNG/Portable Network Graphics
> Files: testWorld.png
>       testWorld.png.aux.xml
> Size is 4096, 4096
> Coordinate System is:
> GEOGCS["WGS 84",
>    DATUM["WGS_1984",
>        SPHEROID["WGS 84",6378137,298.257223563,
>            AUTHORITY["EPSG","7030"]],
>        AUTHORITY["EPSG","6326"]],
>    PRIMEM["Greenwich",0,
>        AUTHORITY["EPSG","8901"]],
>    UNIT["degree",0.01745329251994328,
>        AUTHORITY["EPSG","9122"]],
>    AUTHORITY["EPSG","4326"]]
> Origin = (-180.000000000000000,90.000000000000000)
> Pixel Size = (0.087890625000000,-0.043945312500000)
> Image Structure Metadata:
>  INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (-180.0000000,  90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
> Lower Left  (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
> Upper Right ( 180.0000000,  90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
> Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
> Center      (   0.0000000,   0.0000000) (  0d 0'0.01"E,  0d 0'0.01"N)
> Band 1 Block=4096x1 Type=Byte, ColorInterp=Red
>  Mask Flags: PER_DATASET ALPHA
> Band 2 Block=4096x1 Type=Byte, ColorInterp=Green
> Band 3 Block=4096x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=4096x1 Type=Byte, ColorInterp=Alpha
> This communication is privileged and may contain confidential
> information.  It's intended only for the use of the person or entity
> named above. If you are not the intended recipient, do not distribute
> or copy this communication. If you have received this communication in
> error, please notify the sender immediately and return the original to
> the email address above. © Copyright 2011 Weather Trends
> International, Inc.
International, Inc.
