[gdal-dev] Re: LAS format driver for OGR?
Mateusz Loskot mateusz at loskot.net
Sun Apr 17 17:29:13 EDT 2011
Stefan Keller wrote:
>> Some time ago I have written a tool to dump LAS data to virtually
>> any OGR dataset:
>> http://liblas.org/utilities/las2ogr.html
> I'll have a look at http://liblas.org/utilities/las2ogr.html
> My goal is to import it in PostGIS and a Java program.
las2ogr should work here.
>>> Scanning this mailing list I could not find an answer except to use
>>> LAStools. But since LAS is essentially just a simple vector point data
>> Considering point clouds in terms of (only) a simple vector point data is
>> a misunderstanding.
> You're right. I should have written:
> LAS is essentially vector point data plus a (more or less?) fixed
> number of properties like color.
The extra properties are not the case here. The point is that it is not a
vector data.
A point cloud is neither vector nor raster. It is a raw point cloud which
can be processed depending on your needs, to form of vector or form of
raster.
Dumping a point cloud to PostGIS and trying to make a vector sense of it
without any relevant processing has very little sense, IMHO.
Mateusz Loskot
http://mateusz.loskot.net
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-LAS-format-driver-for-OGR-tp6280076p6281849.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
