[gdal-dev] How can I do to load into a Bitmap an ECW image from GDAL?
    Francisco José Reyes Peralta
    gistdt08 at hotmail.es
    Mon Apr 18 06:26:21 EDT 2011
Dear Jean-Claude,I'm using GDAL 1.8.0, with the csharp dlls loaded into my project.I can load another images but ECW I cannot load into my project.I copy the gdal folder into my bin project folder, I reference the gdal_csharp.dll in it, and activate the gdal in the code:            Dim gdal As String = ";"
            Dim ruta As String = Environment.GetEnvironmentVariable("PATH")
            gdal &= Application.StartupPath & "\GDALx86"
            ruta &= ";" & gdal
            Environment.SetEnvironmentVariable("PATH", ruta)Is needed another dll as the libecwj2.dll?Is supported by GDAL this images actually? In the support formats you can find ECW file supported.I'm using WindowsXP 32bits, and OsGeo.Gdal, OsGeo.OGR, y OsGeo.OSR namespaces.Thanks in advanced.Francisco J.
Le 18/04/2011 11:45, Francisco José Reyes Peralta a écrit :
> Dear friends,
> I'm reading the GDAL documentation, and I'm trying to represent a ECW
> image into a Bitmap in C#.
> The problem is that when I try to load it, it give me an error of Image
> not recognized or bad extension.
> Do I need anything else to load this images using GDAL?
Hello,
What OS are you using ?
What version of GDAL are you using ?
Did you compile GDAL yourself, or did you use a precompiled binary package ?
Jean-Claude
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110418/c401766a/attachment.html
