[gdal-dev] How can I do to load into a Bitmap an ECW image from GDAL?
Francisco José Reyes Peralta gistdt08 at hotmail.es
Mon Apr 18 12:14:51 EDT 2011
Dear Jean-Claude,
How can I put this command?
If i run a for loop for all drivers, I cannot find the ECW plugin.
I put another post to learn how can I install into my application the GDAL plugins to recognize all formats.
Thanks for your help.
Francisco J.
> Date: Mon, 18 Apr 2011 18:12:36 +0200
> From: jrepetto at free.fr
> To: gistdt08 at hotmail.es
> CC: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] How can I do to load into a Bitmap an ECW image from GDAL?
> Le 18/04/2011 17:01, Francisco José Reyes Peralta a écrit :
> > Dear friend,
> > Using, to try gdal 1.8, the following code i cannot find the ECW driver
> > in the list of drivers.
> Have you checked if the command :
> gdalinfo --formats
> reports that the ECW format is supported ?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110418/7dbfbf0f/attachment.html
