[gdal-dev] Re: dev-version of HDF4
Knut-Frode Dagestad knutfrodesoppel at hotmail.com
Wed Apr 20 09:11:55 EDT 2011
I forgot to say, but I have also tried by specifying the location of
HDF4, with similar error:
checking for SDreaddata in -lmfhdfalt... no
checking for SDreaddata in -lmfhdf... no
checking for SDreaddata in -lhdf4... no
configure: error: HDF4 support requested with arg
"/Users/knutfd/Software/hdf-4.2.5/", but neither hdf4 nor mfhdf lib found
HDF4 library is there, but somehow configure is not able to detect it.
HDF4 is compiled without SLIB, so that should not be the problem.
I have also tried with older version of HDF4 (4.2r1), other installation
points, and prebuilt binaries. And I compiled with options
--disable-fortran --disable-netcdf --with-pic, as suggested on
http://osgeo-org.1803224.n2.nabble.com/Error-in-GDAL-compiling-with-HDF4-td3351437.html
It has been suggested to use a "dev" version of HDF4, but I don't know
if that would solve this problem?
Best regards from Knut-Frode
On 19/04/2011 21:51, Nikolaos Hatzopoulos wrote:
> hdf4 libraries not found that's what the log says :)
> do a
> locate libhdf4
> to see where the library is
> On Tue, Apr 19, 2011 at 10:24 AM, Knut-Frode Dagestad
> <knutfrodesoppel at hotmail.com <mailto:knutfrodesoppel at hotmail.com>> wrote:
>     I am trying to compile GDAL from source with support for HDF4 with:
>     ./configure --with-hdf4
>     but get complaints about missing libraries, see extract from config.log:
>     ld: library not found for -lmfhdfalt
>     ld: library not found for -lhdf4
>     configure:19940: checking for SDreaddata in -lmfhdf
>     configure:19965: gcc -o conftest -g -O2   conftest.c -lmfhdf -ldf
>     -lsz -ljpeg -lz -lz -lpthread -ldl >&5
>     configure:20009: error: HDF4 support requested with arg "yes", but
>     Similar errors are also reported by others, e.g. this one using
>     mapserver:
>     http://osgeo-org.1803224.n2.nabble.com/cannot-find-lmfhdf-td5286909.html
>     I have tried with various versions of HDF4, both binaries and
>     compiled from source. The link above (and also
>     http://trac.osgeo.org/gdal/wiki/BuildingOnUnix) suggests to try a
>     "hdf-dev" version. But where can I find such "dev-versions", in my
>     case for Mac OS X 10.6.7?
>     Would it be possible to update GDAL to work with standard HDF4
>     libraries?
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
