[gdal-dev] Re: cropping a tif with lat/lon
Brian Case rush at winkey.org
Thu Apr 21 00:39:38 EDT 2011
Dan
use nearblack to add a alpha or mask band, and collar the image
Brian
On Wed, 2011-04-20 at 19:15 -0700, spalt wrote:
> Hi Brian-
> Thanks so much for your help.  That works, though I feel a little silly now
> because I am realizing the lat/lon the FAA provides with these is the
> corners of the entire map image, not the map itself (these maps have a lot
> of white borders around them, which is what I am trying to crop).  I guess
> it is back to the drawing board.  Anyway, thanks again.
> -Dan
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/cropping-a-tif-with-lat-lon-tp6292065p6293047.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
