[gdal-dev] looking for executable binaries for solaris10
Sophia Parafina creta.kano at gmail.com
Thu Apr 21 09:20:26 EDT 2011
Not that I know of, I recall you need to install gcc, bison, and readline at minimum. Running ./configure will tell you what you are missing. When it stops complaining, run make :)
sophia
On Apr 21, 2011, at 5:55 AM, Imran Rajjad <rajjad at gmail.com> wrote:
> hi Sophia,
> is there any proper walk through or tutorial with steps?
> regards,
> Imran
> On Thu, Apr 21, 2011 at 6:08 PM, Sophia Parafina <creta.kano at gmail.com> wrote:
>> I don't there are any prebuilt binaries for Solaris. I've built gdal using the tool chain (gcc, bison, etc) from here http://www.sunfreeware.com/
>> sophia
>> On Apr 21, 2011, at 4:33 AM, Imran Rajjad <rajjad at gmail.com> wrote:
>>> hi,
>>> is there any executable binary version for solaris 10?
>>> regards,
>>> Imran
>>> I.R
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I.R
