[gdal-dev] Re: cropping a tif with lat/lon
spalt danf at nac.net
Thu Apr 21 15:27:10 EDT 2011
That's a great resource, thx!  I think what I'm missing in order to do the
collar thing is a polygon from the FAA that goes around the actual map
portion of the image.  I've scoured the FAA site and its just not there.
(They have a set of DVD's that contain this same map data that you need to
pay $$$ for to so my suspicion is its there..)
Anyway, what I've been doing is opening each map in QGPS, manually pointing
to the corners and recording them in a database.  Kind of a pain but the
area plotted in the maps doesn't change much so I will only need to do it
once.  Then I can quickly process the whole set without any trouble.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/cropping-a-tif-with-lat-lon-tp6292065p6295306.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
