[gdal-dev] Polygonize from C# ?
Elijah Robison elijah at villagis.com
Fri Apr 22 14:06:46 EDT 2011
Jay, do you basically want a footprint shape of the useful data in the
Sat images (say, without the collar), or is the problem more complex,
where perhaps you have a mosaic of several images and, like swiss
cheese, there are no-data holes within the image?
It sounds to me like you just want a footprint of the collarless area;
is this correct?
/Elijah
Jay Jennings wrote:
> I see, thanks.  But since I have satellite images, this part of the doc is alarming: "...For non-thematic raster data (such as satellite images)
> the result will essentially be one small polygon per pixel, and memory and output layer sizes will be substantial. The algorithm is primarily
> intended for relatively simple thematic imagery, masks, and classification results".
> I just want one polygon enclosing the non-zero pixels (or alternatively, enclosing the zero pixels, then I could do a geometric
> difference).  Is there any way to trick the method into doing that, to maybe avoid the heavy resource needs ?
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Friday, April 22, 2011 11:45 AM
> To: Jay Jennings
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Polygonize from C# ?
> Selon Jay Jennings <Jennings.Jay at geoeye.com>:
> Generally, refering to the C/C++ doc is a good way of finding the info :
> See http://gdal.org/gdal__alg_8h.html#3f522a9035d3512b5d414fb4752671b1
>> Hi list,
>> Can anyone point to any guidance or (preferably) examples on using
>> GDAL.Polygonize() with C# bindings ?  I see what the interface is, but there
>> are some unexplained parameters, e.g. "string[] options".
>> My eventual goal is to open a raster and produce a WKT POLYGON string
>> enclosing the "good" (non-NoData) area of the raster.  Thanks.
>> Jay Jennings
>> Senior Software Developer
>> (NASDAQ: GEOY)
>> jennings.jay at geoeye.com
> gdal-dev mailing list
