[gdal-dev] Using the GDAL/OGR Java bindings with the OSGeo4W environment
MarvinCO marvin.offiah at googlemail.com
Sun Apr 24 13:37:07 EDT 2011
I have installed GDAL and GDAL for Jave with the OSGeo4W installer.
I am using an Eclipse project and have set the JRE that was installed by the
OSGeo4W installer as the JRE to use in my project. I have also added the
gdal.java from OSGeo4W (in the "lib" directory) to the java class path.
Now I'm trying to run this:
System.loadLibrary("gdal18");
ogr.RegisterAll();
ogr.Open(ds, 0);
where "ds" is a certain data source. Unfortunately, I am getting this error:
Native library load failed.
java.lang.UnsatisfiedLinkError: org.gdal.gdal.gdalJNI.HasThreadSupport()I
Exception in thread "main" java.lang.UnsatisfiedLinkError:
org.gdal.ogr.ogrJNI.Open__SWIG_0(Ljava/lang/String;I)J
	at org.gdal.ogr.ogrJNI.Open__SWIG_0(Native Method)
	at org.gdal.ogr.ogr.Open(ogr.java:127)
Why? Can anyone help? As said, I have used the OSGeo4W installer to install
GDAL and GDAL for Java. The installer is supposed to automatically add the
necessary dependencies?
Thanks in advance
Marvin
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-the-GDAL-OGR-Java-bindings-with-the-OSGeo4W-environment-tp6301272p6301272.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
