[gdal-dev] Re: Using the GDAL/OGR Java bindings with the OSGeo4W environment
MarvinCO marvin.offiah at googlemail.com
Sun Apr 24 15:46:45 EDT 2011
Hi Even,
thanks. I have now done that. Could only do that via "Add External Class
Folder" and by choosing "C:\OSGeo4W\bin".
In addition to that, I expanded the "JRE System Library" entry (which is set
to "C:\OSGeo4W") and set the "Native Library location" to "C:\OSGeo4W\bin"
(which is where those DLLs are located).
I even removed the System.loadLibrary("gdal18"), since you said it is
redundant.
But I'm still getting the same error.
What could the problem be? Why "HasThreadSupport"? And what library loads
failed? I though the OSGeo4W installer has already taken care of downloading
dependent libraries. If they are found but still fail to be loaded, why so?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-the-GDAL-OGR-Java-bindings-with-the-OSGeo4W-environment-tp6301272p6301448.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
