[gdal-dev] Split apart MULTI* problem
William Kyngesburye woklist at kyngchaos.com
Tue Apr 26 09:27:05 EDT 2011
I just remembered that what I've done in the past wasn't splitting multi features, but dropping the z from 3D shapefiles.  So I don't know if the multi splitting is possible.
And yes, forcing features to multi into PostGIS is different from splitting multi features into a shapefile.
I suppose I'll have to write a python script...
On Apr 26, 2011, at 3:50 AM, Luca Sigfrido Percich wrote:
> Hi William,
> converting a single linestring or polygon into a multi- geometry simply
> wraps the single geom into a collection. Like in the U.K., when you see
> a single person waiting at a bus stop, it's actually a queue made of a
> single person :)
> Splitting a multi geometry would result in multiple records - one per
> element, probably with the same original attribute values, but with
> different fids, which could be a problem if the original shape already
> had valid primary key values. I'm not sure ogr2ogr can do that, but
> probably there's an appropriate tool around, or you can explode the
> multi geometries in PostGIS.
> Best regards
> Sig
> Da: William Kyngesburye [woklist at kyngchaos.com], 26/04/2011 2.20
>> I can't get ogr2ogr to split MULTI* shapefiles to non-multi features.  I'm sure I've done this in the past (it's been a while).
> _____________
> PRIVACY
> Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
> PRIVACY
> This email was Anti Virus checked by Astaro Security Gateway. http://www.amat-mi.it
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
