[gdal-dev] Mask and GEOTiff
Marius Jigmond mariusjigmond at hotmail.com
Thu Apr 28 19:13:46 EDT 2011
In QGIS you can use Raster Calculator to multiply the rasters.
-marius
On Thu, 2011-04-28 at 00:30 -0700, canduc17 wrote:
> Hi everyone.
> Is there a way to crop a GEOTiff image using a Mask of the same dimension?
> For example, a mask with a filled circle: every pixel inside the circle is 1
> and the others are 0.
> I would like to obtain a new GEOTiff with only the pixel inside the circle
> visible and the other set to 0.
> Is that possible with tools like gdal_translate or other ones?
> Thanks in advance!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mask-and-GEOTiff-tp6312284p6312284.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
