[gdal-dev] FGDB Opening Sample File
Smith, Michael ERDC-CRREL-NH michael.smith at usace.army.mil
Fri Apr 29 06:49:33 EDT 2011
Paul,
They are tables and the links between them (as far as I can tell).
See
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Relationship_c
lass_properties/004t00000004000000/
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 4/28/11 5:30 PM, "Paul Ramsey" <pramsey at opengeo.org> wrote:
> Are they tables or links between tables?  I can see this is going to
> be a hard project to do without ArcGIS handy :)
> P.
> On Thu, Apr 28, 2011 at 10:26 AM, Smith, Michael ERDC-CRREL-NH
> <michael.smith at usace.army.mil> wrote:
>> Relations are joins to non-spatial tables containing domain values etc. They
>> are relational tables.
>> Mike
>> Michael Smith
>> On 4/28/11 1:19 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>>> Le jeudi 28 avril 2011 02:11:30, Paul Ramsey a écrit :
>>>> I assume the failures are relationships we don't handle yet (or ever
>>>> and will need to be silenced).
>>> Not sure what those relations things are.
>>>> There is a test file in the FGDB API itself, and it fails to open
>>>> entirely, which seems odd,
>>>> [pramsey at localhost data]$ ogrinfo ./TestData.gdb
>>>> ERROR 1: GDB Error: Failed to open Geodatabase long:-2147467259
>>>> FAILURE:
>>>> Unable to open datasource `./TestData.gdb' with the following drivers.
>>>> Do other folks have trouble opening the ESRI sample file? The error
>>>> code doesn't make much sense, it is supposed to mean "If the path is
>>>> seriously in error, say pointing to the wrong drive, a -2147467259
>>>> (E_FAIL) error is returned" and relates to the CreateGeodatabase
>>>> method, not the OpenGeodatabase method.
>>> Yes I did notice that issue too. I assume either the example is corrupted,
>>> either it is a bug in the FileGDB API, either... Perhaps reporting to ESRI
>>> might be usefull. Or perhaps Ragi has some clues.
>>> Even
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
