[gdal-dev] Raster size and ReadAsArray()
Jay L. jzl5325 at psu.edu
Wed Aug 3 11:04:18 EDT 2011
I have been working on this problem as well.  Initially, the attempt was to
ReadAsArray small chunks.  Unfortunately this is quite inefficient.  Someone
more knowledgeable will know why, but I suspect it has to do with either
thrashing or the fact that full blocks are not being read in (as is the case
when a 5000x5000 pixel block is read in on a 12567, 12764 GTiff).
My intention this morning is to try to implement an if statement which
checks total file size and breaks it down into manageable (500MB maybe)
chunks.  Then using numpy slices, I can read, slice, mask, and manipulate as
needed.
Again, the biggest issue I have had with this issue is performance.
 Profiling shows that _gdal.IORaster is utilizing a ton of CPU time.
Hope that helps,
Jay
On Wed, Aug 3, 2011 at 7:39 AM, Antonio Valentino <
antonio.valentino at tiscali.it> wrote:
> Hi Alexander,
> Il 03/08/2011 15:35, Alexander Bruy ha scritto:
> > Hi,
> > There is a well-know "problem": reading really large rasters or bands
> > into memory with DataSource.ReadAsArray() method impossible due
> > memory limitations. For example, when I try to read one band with
> > size 53109x29049 I get error:
> [CUT]
> > I want to know is it possible to get maximum raster size that can be
> handled
> > using ReadAsArray() without errors because I want to implement a fallback
> > algorithm for large rasters in my tool.
> In my experience using too large chunks of memory can cause,
> paradoxically, slowdowns.
> My suggestion is to define a reasonable maximum size for arrays in your
> application/library and switch to the "fallback algorithm for large
> rasters" every time that MAX_SIZE is exceeded, even if using ReadAsArray
> still works.
> > Currently I try to implement it with try-except statement but maybe
> > there is more
> > elegant solution?
> > Thanks
> IMHO using try-except *is* elegant and perfectly in line with python's
> philosophy.
> best regards
> Antonio Valentino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110803/7133c4a0/attachment-0001.html
