[gdal-dev] How to register ArcSDE driver
Tamas Szekeres szekerest at gmail.com
Tue Aug 9 15:32:31 EDT 2011
Make sure to place the ogr_SDE.dll into the /gdalplugins subdirectory from
where your application is running. Alternatively you can set the
GDAL_DRIVER_PATH environment setting to point to the directory of the plugin
dll-s
Best regards,
Tamas
2011/8/9 L.M Tan <konglongbt at gmail.com>
> hi,
> I am interested in using *OGR *to read data from an ArcSDE (9.2-9.3)
> database. I have built ogr_SDE.dll,but i can not open the SDE database.
> This is the csharp code :
>             Ogr.RegisterAll();
>             Driver sdedr = Ogr.GetDriverByName("SDE");       //   sdedr =
> null
>             /*      Open data source.
>             DataSource ds = Ogr.Open("SDE:192.168.1.123,5151,sde,sde,sde",
> 0);     //   ds=null
> I want to know how to register ArcSDE driver.
> TIA for any advice you might give and have a great day!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110809/4380ebbb/attachment.html
