[gdal-dev] Re: How to use gdalinfo for HDF- Windows
Luisa Peña luisapena1979 at gmail.com
Wed Aug 10 04:55:24 EDT 2011
Hey Brent
I'm using ESA's GLOBCOVER data.In this case I'm trying to set a GRASS script
to run gdal directly.
I do:
gdalinfo C:\data\GL.hdf and I retrieve all basic information plus HDF's
layers
Driver: HDF4/Hierarchical Data Format Release 4
Files: c:\data\GL.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
  HDFEOSVersion=HDFEOS_V2.12
Subdatasets:
  SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_1
  SUBDATASET_1_DESC=[1800x1800] MEAN_1 POSTEL (16-bit integer)
 SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_2
  SUBDATASET_2_DESC=[1800x1800] MEAN_2 POSTEL (16-bit integer)
  SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_3
  SUBDATASET_3_DESC=[1800x1800] MEAN_3 POSTEL (16-bit integer)
  SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_4
  SUBDATASET_4_DESC=[1800x1800] MEAN_4 POSTEL (16-bit integer)
  SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_5
then:
gdalinfo HDF4_EOS:EOS_GRID:"c:\data\GL.hdf":POSTEL:MEAN_1
I get:
ERROR 4: 'HDF4_EOS:EOS_GRID:c:\data\GL.hdf:POSTEL:MEAN_1'
does not exist in fyle system, and is not recognised as a supported dataset
name.
gdalinfo failed- unable to open
'HDF4_EOS:EOS_GRID:c:\data\GL.hdf:POSTEL:MEAN_1''
open GDAL Datasets:
1 N DriverIsNULL 512x512x0
But if I do:
 gdalinfo HDF4_EOS:EOS_GRID:":\data\GL.hdf":POSTEL:MEAN_1
it works (without the C from the driver)
The problem is that if I'm trying to to use data in D it does not work.
Any suggestions?
2011/8/9 Brent Fraser <bfraser at geoanalytic.com>
> Luisa,
>   I use GDAL to access MODIS data in HDF4 on Windows like this:
> gdalinfo
> HDF4_EOS:EOS_SWATH:"G:\Projects\temp\image3\MOD02HKM.A2011186.1640.005.NRT.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB
> So I'd suggest using double quotes around your path.
> Best Regards,
> Brent Fraser
> On 8/9/2011 8:24 AM, Luisa Peña wrote:
>  Greetings
> This seems odd but it does not work with
> HDF4_EOS:EOS_GRID:C:/filepath
> only
> HDF4_EOS:EOS_GRID:filepath
> And if my MERIS data is not placed in my main hard disk (C:) it does not
> work.
> Anyone with some experience on this in WINDOWS?
> Thanks
> Luisa
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110810/d9065108/attachment.html
