[gdal-dev] C# Bindings warp image using gcp
Even Rouault even.rouault at mines-paris.org
Wed Aug 10 14:40:14 EDT 2011
Le mercredi 10 août 2011 15:40:33, Edi.Karadumi a écrit :
> Hello im trying to warp an image using 4 or more gcp points. I have already
> done it in c++, but my project is in c# so im trying to convert it. I got
> the following example from the GDAL warp API tutorial and adjusted it for
> my needs. I have done most of the other parts but i cant convert the
> following part
> // Establish reprojection transformer.
>     psWarpOptions->pTransformerArg =
>         GDALCreateGenImgProjTransformer( hSrcDS,
>                                          GDALGetProjectionRef(hSrcDS),
>                                          hDstDS,
>                                          GDALGetProjectionRef(hDstDS),
>                                          TRUE, 0.0, 1 );
>     psWarpOptions->pfnTransformer = GDALGenImgProjTransform;
> I cant find GDALCreateGenImgProjTransformer to create the transformer. How
> can i adapt it i C#?
There's no SWIG bindings for using those low level warp API. The closes match
I see is the gdal.ReprojectImage() API that will establish a
GenImgProjTransform and proceed to the warping itself. You can see its C++
implementation here :
http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdalwarper.cpp
> Best Regards
> Edi Karadumi
> This is the official Example
> #include "gdalwarper.h"
> int main()
>     GDALDatasetH  hSrcDS, hDstDS;
>     // Open input and output files.
>     GDALAllRegister();
>     hSrcDS = GDALOpen( "in.tif", GA_ReadOnly );
>     hDstDS = GDALOpen( "out.tif", GA_Update );
>     // Setup warp options.
>     GDALWarpOptions *psWarpOptions = GDALCreateWarpOptions();
>     psWarpOptions->hSrcDS = hSrcDS;
>     psWarpOptions->hDstDS = hDstDS;
>     psWarpOptions->nBandCount = 1;
>     psWarpOptions->panSrcBands =
>         (int *) CPLMalloc(sizeof(int) * psWarpOptions->nBandCount );
>     psWarpOptions->panSrcBands[0] = 1;
>     psWarpOptions->panDstBands =
>     psWarpOptions->panDstBands[0] = 1;
>     psWarpOptions->pfnProgress = GDALTermProgress;
>                                          hDstDS,
>                                          FALSE, 0.0, 1 );
>     // Initialize and execute the warp operation.
>     GDALWarpOperation oOperation;
>     oOperation.Initialize( psWarpOptions );
>     oOperation.ChunkAndWarpImage( 0, 0,
>                                   GDALGetRasterXSize( hDstDS ),
>                                   GDALGetRasterYSize( hDstDS ) );
>     GDALDestroyGenImgProjTransformer( psWarpOptions->pTransformerArg );
>     GDALDestroyWarpOptions( psWarpOptions );
>     GDALClose( hDstDS );
>     GDALClose( hSrcDS );
>     return 0;
> http://osgeo-org.1803224.n2.nabble.com/C-Bindings-warp-image-using-gcp-tp6
> 672396p6672396.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
