[gdal-dev] Re: How to use gdalinfo for HDF- Windows
Even Rouault even.rouault at mines-paris.org
Wed Aug 10 14:49:03 EDT 2011
you didn't mention which GDAL version you are using. Since Brent manages to
make it work with a very similar command line that the one that fails for you,
I highly suspect you are using an old version. There was indeed a bug very
similar to your issue ( http://trac.osgeo.org/gdal/ticket/2823 ) that has been
fixed in GDAL 1.6.1.
Best regards,
