[gdal-dev] save raster as point-vector file
Mateusz Kędzior matandked at gmail.com
Thu Aug 11 14:17:31 EDT 2011
Hi Chaitanya,
I try to add full path to csv file - is it correct?
===================================================NEW VRT
FILE====================================
<OGRVRTDataSource>
    <OGRVRTLayer name="evap_OBCXYZn">
<SrcDataSource>"/media/windows/studia/2_sem_mgr/mgr/prof_Zawadzki/dods/gldas/00Z07Apr2009_00Z15Apr2009/evap_OBCXYZn.csv"</SrcDataSource>
        <GeometryType>wkbPoint</GeometryType>
        <LayerSRS>WGS84</LayerSRS>
        <GeometryField encoding="PointFromColumns" x="Longitude"
y="Latitude"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
When I try use ogrinfor I get an error message:
FAILURE:
Unable to open datasource `evap_OBCXYZn.vrt' with the following drivers.
When I use the same tool at csv file I get:
INFO: Open of `evap_OBCXYZn.csv'
      using driver `CSV' successful.
1: evap_OBCXYZn (None)
The CSV file contain such information:
Longitude,Latitude,Name
20.132145,52.4227439,1.78132e-05
20.382145,52.4227439,1.89083e-05
and so on..
How I can change it to get vector-point layer? As I wrote I can only get a
layer without geometry if I point to csv file.
Best regards,
Mateusz
W dniu 11 sierpnia 2011 10:04 użytkownik Chaitanya kumar CH <
chaitanya.ch at gmail.com> napisał:
> What is the output of ogrinfo on the .vrt file?
> 2011/8/11 Mateusz Kędzior <matandked at gmail.com>
>> Hi Chaitanya,
>> I say that I don't need to create VRT file, but I was wrong. When I try to
>> run ogr2ogr utility:
>> ogr2ogr -f GML output_file.gml input_file.csv*
>> I discover that created file contain only table - if I choose ESRI
>> shapefile as output, I get only dbf file.
>> So i try to generate such file:
>> <OGRVRTDataSource>
>>     <OGRVRTLayer name="evap_OBC_OBCXYZn">
>>         <SrcDataSource>evap_OBC_OBCXYZn.csv</SrcDataSource>
>> y="Latitude"/>
>>     </OGRVRTLayer>
>> </OGRVRTDataSource>
>> but:
>>    - if I type .vrt file as input I get an empty GML file
>>    - if I I type .csv file as input I get an output which contain only
>>    table (without geometry)
>> How I can run it properly?
>> Which values are allowed in <GeometryField encoding> property?
>> Best regards,
>> Mateusz
>> W dniu 10 sierpnia 2011 05:58 użytkownik Chaitanya kumar CH <
>> Mateusz,
>>> You have to change the OGRVRTLayer name property to point to the file
>>> name without the extension.  Also change the SrcDataSource element.
>>> FYI, this process creates a vector file with points. gdal_polygonize
>>> produces polygons.
>>> 2011/8/10 Mateusz Kędzior <matandked at gmail.com>
>>>> Hi again,
>>>> is it mandatory to create such file?
>>>> Regarding to information on GDAL/OGR page should I create simple text
>>>> file which contains only other OGRVRTLayer name property :
>>>> <OGRVRTDataSource>
>>>>     <OGRVRTLayer name="test">
>>>>         <SrcDataSource>test.csv</SrcDataSource>
>>>>         <GeometryField encoding="PointFromColumns" x="Longitude" y="Latitude"/>
>>>>     </OGRVRTLayer>
>>>> </OGRVRTDataSource>
>>>> Best regards,
>>>> Mateusz
>>>> W dniu 9 sierpnia 2011 20:13 użytkownik Chaitanya kumar CH <
>>>>> Create a text file with just the header. Use the cat command to join
>>>>> this file and the xyz file.
>>>>> $ cat HeaderFile.csv file1.csv > file1.cHi sv
>>>>> You can repeat this on all files in a shell script.
>>>>> Otherwise add the following line in the gdal2xyz.py script at line 144
>>>>> [1].
>>>>> dst_fh.write( 'Longitude,Latitude,Name' )
>>>>> You will also have to create a separate vrt file for each csv file. The
>>>>> SrcDataSource element value changes for each file.
>>>>> [1]:
>>>>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal2xyz.py?rev=21127#L145
>>>>> 2011/8/9 Mateusz Kędzior <matandked at gmail.com>
>>>>>> Chaitanya,
>>>>>> if I understand properly, I need to add one line to each of processed
>>>>>> files.
>>>>>> How I can do it quickly? Is there any option in gdal2xyz.py script?
>>>>>> If no - what would You recommend?
>>>>>> I think about sed utility, but it's general difficult in use.
>>>>>> When I am thinking about Python I see only one possibility - load each
>>>>>> file to variable and then assign to another first line plus variable and at
>>>>>> last - save it.
>>>>>> Best Regards,
>>>>>> Mateusz
>>>>>> W dniu 9 sierpnia 2011 13:38 użytkownik Chaitanya kumar CH <
>>>>>> Mateusz,
>>>>>>> gdal2xyz.py creates space delimited fields. Consider running it with
>>>>>>> the -csv option to delimit it with comma.
>>>>>>> Now you can almost use it as a csv format vector file. You just need
>>>>>>> to add a header row and define a small VRT file as described in OGR's CSV
>>>>>>> driver page[1].
>>>>>>> Run ogrinfo and ogr2ogr on the .vrt file to check the file.
>>>>>>> [1]: http://www.gdal.org/ogr/drv_csv.html
>>>>>>>> Hello,
>>>>>>>> I would like to show value of each raster cell as label. My idea (I
>>>>>>>> don't know any plugin or any functionality in GDAL/OGR which allow to do it
>>>>>>>> easier) is to export raster using gdal2xyz.py into coordinates-value format
>>>>>>>> and then save it as vector (GML or shapefile). For this second task, I try
>>>>>>>> to use
>>>>>>>> gdal_polygonize.py:
>>>>>>>> gdal_polygonize.py rainfXYZ.txt rainf.shp Creating output rainf.shp
>>>>>>>> of format GML. 0...10...20...30...40...50...60...70...80...90...100 - done.
>>>>>>>> unfortunately I am unable to load created file (even if I change the
>>>>>>>> extension to .gml)
>>>>>>>> ogr2ogr tool don't even recognize this format.
>>>>>>>> Thank You in advance,
>>>>>>>> Mateusz
>>>>>>>> _______________________________________________
>>>>>>>> gdal-dev mailing list
>>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>>> Best regards,
>>>>>>> Chaitanya kumar CH.
>>>>>>> +91-9494447584
>>>>>>> 17.2416N 80.1426E
>>>>> Best regards,
>>>>> Chaitanya kumar CH.
>>>>> +91-9494447584
>>>>> 17.2416N 80.1426E
>>> Best regards,
>>> Chaitanya kumar CH.
>>> +91-9494447584
>>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110811/31f3a93a/attachment-0001.html
