[gdal-dev] gdal_translate eats projection parameter values
Hermann Peifer peifer at gmx.eu
Fri Aug 12 10:24:58 EDT 2011
PARAMETER["Central_Meridian",10.0] from the projection file comes out
as: PARAMETER["longitude_of_center",0]
PARAMETER["Latitude_Of_Origin",52.0] is changed to
PARAMETER["latitude_of_center",0]
See the details below. Is there something wrong with my projection file
or rather with GDAL?
Wondering, Hermann
PS: I am using gdal from trunk, revision 22757 from
2011-07-19T18:57:35.878941Z
PPS: I reported a somewhat similar (?) issue 2 years ago, see
http://trac.osgeo.org/gdal/ticket/3016
$ cat dummy.asc
ncols        1
nrows        1
xllcorner    0.0
yllcorner    0.0
cellsize     50.0
NODATA_value -9999
-9999
$ cat ETRS_1989_LAEA_L52_M10.prj
PROJCS["ETRS_1989_LAEA_L52_M10",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",4321000.0],PARAMETER["False_Northing",3210000.0],PARAMETER["Central_Meridian",10.0],PARAMETER["Latitude_Of_Origin",52.0],UNIT["Meter",1.0]]$
$ gdal_translate dummy.asc dummy.tif -a_srs ETRS_1989_LAEA_L52_M10.prj
Input file size is 1, 1
0...10...20...30...40...50...60...70...80...90...100 - done.
$ gdalinfo dummy.tif
Driver: GTiff/GeoTIFF
Files: dummy.tif
Size is 1, 1
Coordinate System is:
             SPHEROID["GRS_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PARAMETER["latitude_of_center",0],
     PARAMETER["longitude_of_center",0],
     PARAMETER["false_easting",4321000],
     PARAMETER["false_northing",3210000],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]]]
Origin = (0.000000000000000,50.000000000000000)
Pixel Size = (50.000000000000000,-50.000000000000000)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (   0.0000000,  50.0000000) ( 43d40' 8.77"W, 27d18'43.27"S)
Lower Left  (   0.0000000,   0.0000000) ( 43d40' 9.28"W, 27d18'44.80"S)
Upper Right (  50.0000000,  50.0000000) ( 43d40' 6.89"W, 27d18'43.45"S)
Lower Right (  50.0000000,   0.0000000) ( 43d40' 7.41"W, 27d18'44.97"S)
Center      (  25.0000000,  25.0000000) ( 43d40' 8.09"W, 27d18'44.12"S)
Band 1 Block=1x1 Type=Int32, ColorInterp=Gray
   NoData Value=-9999
