[gdal-dev] Help with GDAL & Visual Studio 2010 & netCDF
James Sulzman sulzman at casco.net
Mon Aug 15 15:09:19 EDT 2011
Hi All,
I could use a little help, and it would be greatly appreciated.
Goal:  Write a c++ program in MS Visual Studio 2010 (on win7 x64 machine)
that reads in a netCDF file.  Compile/build program in Visual Studio 2010
Release or Debug x64.  Execute the program.
The netCDF file I am trying to read in, has one variable in it.  That
variable is a 3d raster 76x40x93 of float32 type.
Steps I have taken:
1.       Download binaries from
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-
1-8-mapserver-6-0.zip
2.       Create .lib files from .dll(s)
3.       Follow instruction from download binary site, paths/linkers to
library and gdalplugins etc..
4.       Use code from API tutorial for c++
http://www.gdal.org/gdal_tutorial.html, also pasted below
5.       Compile the program (everything compiles fine).
6.       Run the program, does not bomb, but offers bad results.
7.       If you look at the c++ code tutorial in step 4 it has various print
statements. Here are the results from those print statements
Driver: netCDF/Network Common Data Format
Size is 76x40x93
Projection is ' '
Block=76x1 Type=Float32, ColorInterp=Undefinded
Min=72.905d Max 115.625d
Data=100.216d
Problem:
When I get a "band" and get the block size, the block size  is reported as
76x1 (as in the snips below).  I expected the block size to be 76x40
poBand = poDataset->GetRasterBand( 1 );
poBand->GetBlockSize( &nBlockXSize, &nBlockYSize );
When I read the block (putting the snip below in a nested loop for column
and row) I get the proper data in that 76x1 (76 values) block, but I can't
move onto the next row (ie row > 0). Which makes sense because the block is
only 76x1.  Also, if I get band "2" the same thing, good data, but only one
column to work with.  What am I missing?  How do I retrieve the full band of
76x40?  I even tried a JPEG file and got similar results?
poBand->RasterIO( GF_Read, column, row, nXSize, 1,
                          pafScanline, nXSize, 1, GDT_Float32,
                          0, 0 );
Thanks in advance for any help or advice,
James
My program
typedef __int64 _OFF_T;
#include "gdal.h"
#include "gdal_priv.h"
#include "netcdf.h"
#include "gdal_frmts.h"
#include "netcdfdataset.h"
#include "cpl_config.h"
#include "cpl_conv.h"
#include "cpl_error.h"
#include "cpl_hash_set.h"
#include "cpl_port.h"
#include "cpl_string.h"
#include "cpl_vsi.h"
#include "cpl_minixml.h"
#include "gdal_pam.h"
#include "gdal_version.h"
#include "gdal_vrt.h"
#include "ogr_core.h"
#include "ogr_spatialref.h"
#include "ogr_srs_api.h"
#include <iostream>
using namespace std;
//const char *pszFilename = "\\IMG_3527.jpg";
//const char *pszFilename = "\\hada2eugsi.nc";
const char *pszFilename = "\\james_test.nc";
//const char *pszFilename = "\\CRUTEM3.nc";
const char *netcdfmeta ("");
char ** ppinfo;
int * pncid;
int main()
    GDALAllRegister();
       GDALDriver *poDriver = (GDALDriver *) GDALGetDriverByName( "VRT" );
       poDataset = (GDALDataset *) GDALOpen( pszFilename, GA_ReadOnly );
       GDALGetMetadata(poDataset,netcdfmeta);
       //poDataset->GetPamInfo();
       poDataset->GetMetadata(netcdfmeta);
       GDALOpenInfo(pszFilename, GA_ReadOnly ,ppinfo);
       //GDALGetGeoTransform( GDALDatasetH, double * );
       if( poDataset == NULL )
       printf( "did not open file");
       double        adfGeoTransform[6];
    printf( "Driver: %s/%s\n",
            poDataset->GetDriver()->GetDescription(),
            poDataset->GetDriver()->GetMetadataItem( GDAL_DMD_LONGNAME ) );
    printf( "Size is %dx%dx%d\n",
            poDataset->GetRasterXSize(), poDataset->GetRasterYSize(),
            poDataset->GetRasterCount() );
    if( poDataset->GetProjectionRef()  != NULL )
        printf( "Projection is `%s'\n", poDataset->GetProjectionRef() );
    if( poDataset->GetGeoTransform( adfGeoTransform ) == CE_None )
        printf( "Origin = (%.6f,%.6f)\n",
                adfGeoTransform[0], adfGeoTransform[3] );
        printf( "Pixel Size = (%.6f,%.6f)\n",
                adfGeoTransform[1], adfGeoTransform[5] );
       GDALRasterBand  *poBand;
        int             nBlockXSize, nBlockYSize;
        int             bGotMin, bGotMax;
        double          adfMinMax[2];
        printf( "Block=%dx%d Type=%s, ColorInterp=%s\n",
                nBlockXSize, nBlockYSize,
                GDALGetDataTypeName(poBand->GetRasterDataType()),
                GDALGetColorInterpretationName(
                    poBand->GetColorInterpretation()) );
        adfMinMax[0] = poBand->GetMinimum( &bGotMin );
        adfMinMax[1] = poBand->GetMaximum( &bGotMax );
        if( ! (bGotMin && bGotMax) )
            GDALComputeRasterMinMax((GDALRasterBandH)poBand, TRUE,
adfMinMax);
        printf( "Min=%.3fd, Max=%.3f\n", adfMinMax[0], adfMinMax[1] );
        if( poBand->GetOverviewCount() > 0 )
            printf( "Band has %d overviews.\n", poBand->GetOverviewCount()
        if( poBand->GetColorTable() != NULL )
            printf( "Band has a color table with %d entries.\n",
                     poBand->GetColorTable()->GetColorEntryCount() );
              float *pafScanline;
        int   nXSize = poBand->GetXSize();
        pafScanline = (float *) CPLMalloc(sizeof(float)*nXSize);
        poBand->RasterIO( GF_Read, 0, 0, nXSize, 1,
                          0, 0 );
              printf( "data=%.3fd", *pafScanline );
              GDALClose(poDataset);
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110815/b4fe8225/attachment-0001.html
