[gdal-dev] Help with GDAL & Visual Studio 2010 & netCDF
Ben Discoe ben at vterrain.org
Wed Aug 17 12:53:14 EDT 2011
James,
In this case, it may be simpler, easier and more efficient to simply call
the NetCDF library directly, rather than going through GDAL.  Your
particular file sounds like a 3D dataset, which is stretching the bounds of
what GDAL is designed to handle, namely rasters.
The NetCDF API is relatively straightforward.  There is documentation and
examples.
-Ben
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] On Behalf Of James Sulzman
> Sent: Monday, August 15, 2011 12:09 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Help with GDAL & Visual Studio 2010 & netCDF
> Hi All,
> I could use a little help, and it would be greatly appreciated.
> Goal:  Write a c++ program in MS Visual Studio 2010 (on win7 x64 machine)
> that reads in a netCDF file.  Compile/build program in Visual Studio 2010
> Release or Debug x64.  Execute the program.
> The netCDF file I am trying to read in, has one variable in it.  That
> variable is a 3d raster 76x40x93 of float32 type.
