[gdal-dev] gdalwarp capability to output as netCDF format
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 19 02:11:10 EDT 2011
Hendy,
gdalwarp is a utility that uses the gdal library. It can read/write in
netCDF format if the library is built with netCDF capability[1]. To check if
your installation has that capability, use the command "gdalwarp --formats".
[1]: http://www.gdal.org/formats_list.html
On Fri, Aug 19, 2011 at 11:22 AM, Hendy Sumanto <hsumanto at vpac.org> wrote:
> Hi Everyone,
> Just wondering if there is work currently being done to add the capability
> into gdalwarp.
> Regards,
> Hendy
> Hendy Sumanto
> Software Developer
> Victorian Partnership for Advanced Computing (VPAC)
> Innovation Powered by Advanced Computing
> http://www.vpac.org
> t: +61 3 9020 0191 (TC)
> t: +61 3 9647 5437 (FB)
> f: +61 3 9646 7787
> m: +61 4 1258 0874
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110819/92143604/attachment.html
