[gdal-dev] Re: Dump Shapefile into DB using ogr2ogr
Hermann Peifer peifer at gmx.eu
Fri Aug 19 11:53:00 EDT 2011
On 19/08/2011 15:05, Ingo Weinzierl wrote:
> Thanks for the quick reply, but the "-select" option only solves one
> of the two parts of my problem. I still need to append a further
> column that does not exist in the shapefile and which should be
> defined manually.
I am not sure if I fully understood the issue, but... what about:
... -sql "select cast(999 as integer(3)) as field from ..."
(If you want an additional integer column with name `field', where all
values are defined to be 999)
Hermann
