[gdal-dev] How would I build a custom pyramid ?
Alain Camus aca at ngi.be
Mon Aug 22 07:05:04 EDT 2011
Hello list,
I have a set of tiles at resolution 0.5 m/pxl. Based on this data, I'd like to create a pyramid that has zoom levels 0.166667, 0.333333, 0.666667 and 1.66667 (the data will only be viewed in geoserver at these levels, so I guess it will be faster if I prepare the data at these levels).
I think gdal_retile only allows multiplying the zoom levels by 2. Thus I think I will need those steps :
    1. gdal_translate to get the lowest zoom level (0.5 --> 0.166667)
    2. gdal_retile to give these tiles the good size in pixels, mosaic them and to create the next two levels (0.333333 and 0.666667 )
    3. gdal_translate again to get the highest zoom level (1.66667 , which is not the double of the previous one) starting from the 0.666667 tiles .
    4. gdal_retile again to give these tiles the good size in pixels and mosaic them
    5. manually adapt the pyramid config files
At 0.5 m/pxl, I have 8000 geotiffs each 4000 x 4000 pxls, so I think it'll take a lot of time, especially steps 1 and 2.
Would you have an advice to speed up the process or decrease the number of steps ?
Alain
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110822/298b4ac7/attachment.html
