[gdal-dev] gdal_rasterize output off by one pixel/cell
Eli Adam EAdam at co.lincoln.or.us
Mon Aug 22 12:50:15 EDT 2011
Matt,
     You may want to look at this ticket and see if it is the same thing. If so, you can add yourself to the cc list and you will get emails when there are updates to the ticket.  You can also add any additional relevant information to the ticket.
http://trac.osgeo.org/gdal/ticket/3774
Regards, Eli
>>> On 8/20/2011 at 11:06 AM, in message
<AA52F8AC-89DC-4543-A210-0DD0BA9E58FD at my.und.edu>, "Burton-Kelly, Matthew"
<matthew.burton.kelly at my.und.edu> wrote:
> Hello,
> I'm attempting to create a raster from a shapefile of point data, with grid
> cells 1 degree square.  Although the area I have defined matches up with the
> origin coordinates I want, and the grid cells match up with a vector 1-degree
> grid I produced in QGIS, the squares supposedly containing the point data are
> shifted, it looks like down and to the right.  Has anyone encountered this
> issue before?
> Here is the command I used:
> gdal_rasterize -a <column name> -ts 360 180 -te -180 -90 180 90 -l <source layer name
> in source file> <source file> <destination file>
> I have uploaded a screenshot of the output I am describing here:
> http://www.flickr.com/photos/matthewbk/6059112633
> Thanks for any insight,
> Matt
> Matthew Burton-Kelly, M.S.
> Graduate Student
> Department of Geology and Geological Engineering
> University of North Dakota
> Mobile: (802) 922-3696
> matthew.burton.kelly at my.und.edu<mailto:matthew.burton.kelly at my.und.edu>
> matthew.burtonkelly at gmail.com<mailto:matthew.burtonkelly at gmail.com>
> http://www.protichnoctem.com
> http://und.academia.edu/MatthewBurtonKelly
> "About thirty years ago there was much talk that geologists ought only to
> observe and not theorize; and I well remember someone saying that at this
> rate a man might as well go into a gravelpit and count the pebbles and
> describe the colors.  How odd it is that anyone should not see that all
> observation must be for or against some view if it is to be of any service!"
> -Charles Darwin, in an 1861 letter to Henry Fawcett.
