[gdal-dev] gdalwarp: max, min, avg of the overlapping image area
Daniela Czibener daniela.czibener at gmail.com
Mon Aug 22 19:57:17 EDT 2011
I'm using gdalwarp with two images that are not in the same location, but
have a common area.
In the common area, I'd like the resulting pixels values will be the maximum
or average value, not the value of the last image in the source image list.
Is there any option within the gdalwarp or I should use another GDAL tool?
Thanks in advance,
Daniela.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110822/5904fd80/attachment.html
