[gdal-dev] Re: gdalwarp capability to output as netCDF format
Hendy Sumanto hsumanto at vpac.org
Wed Aug 24 04:50:40 EDT 2011
I probably should change the question to this to make it clearer.
Does anyone know whether there is plan to implement Create method for netCDF driver as currently it is only support only CreateCopy method?
If no, could someone please describe what steps would be involved to add this method to the netCDF driver as I am pretty new to GDAL.
Thanks.
Regards,
Hendy
