[gdal-dev] Using GDAL to tile an image *with* overlapping?
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Aug 24 05:20:36 EDT 2011
Jonathan,
I think you will have to modify the gdal_retile.py script[1] yourselves.
Can you explain what you mean by the shapefile of the results?
[1]:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal_retile.py
On Wed, Aug 24, 2011 at 2:17 AM, Jonathan Greenberg <jgrn at illinois.edu>wrote:
> GDALers:
> I really like gdal.retile.py, but I'm now facing an issue where I want
> to tile a file but have *overlap* between each tile.  Is there a way
> to do this using existing GDAL utilities?  I want the outputs to be
> geotiffs, and (ideally, but not required) I'd like a shapefile
> generated of the results.  Thanks!
> --j
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110824/8193c429/attachment.html
