[gdal-dev] OGR csv driver: feature numbering
Hermann Peifer peifer at gmx.eu
Sat Aug 27 06:07:12 EDT 2011
I am just wondering why the csv driver starts numbering at 1, rather
than at 0, see e.g. the "First point" in the test.csv example at [1],
which ends up as OGRFeature(test):1.
However, if I take the test.vrt/test.csv example and convert it to
shapefile format, I end up with features 0, 1 and 2, see [2].
Is this how it should be?
Hermann
[1] http://www.gdal.org/ogr/drv_csv.html
[2]
$ ogr2ogr test.shp test.vrt
$ ogrinfo -al test.shp
INFO: Open of `test.shp'
       using driver `ESRI Shapefile' successful.
Layer name: test
Geometry: Point
Feature Count: 3
Extent: (0.250000, 47.500000) - (1.100000, 49.200000)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
     DATUM["WGS_1984",
         SPHEROID["WGS_84",6378137,298.257223563]],
     PRIMEM["Greenwich",0],
     UNIT["Degree",0.017453292519943295]]
Latitude: String (80.0)
Longitude: String (80.0)
OGRFeature(test):0
   Latitude (String) = 48.1
   Longitude (String) = 0.25
   Name (String) = First point
   POINT (0.25 48.1)
OGRFeature(test):1
   Latitude (String) = 49.2
   Longitude (String) = 1.1
   Name (String) = Second point
   POINT (1.1 49.2)
OGRFeature(test):2
   Latitude (String) = 47.5
   Longitude (String) = 0.75
   Name (String) = Third point
   POINT (0.75 47.5)
