[gdal-dev] OGR Spatialite driver and spatial index
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Aug 29 03:39:45 EDT 2011
Does the OGR SQLite/Spatialite driver really utilise the spatial
index if such exists in the Spatialite database? The documentation
suggests so http://gdal.org/ogr/drv_sqlite.html.  However, I haven't
been able to see any difference in my speed tests with ogr yet.
I made a set of tests with ogrinfo against a Spatialite database
with and without spatial index. These two tests took the same 30
seconds to run both with and without spatial index.
ogrinfo OSM_Finland.sqlite -sql "select geometry, osm_id ,highway,ref,
name, tunnel from osm_line where highway is not null"
-spat  389116 6677305 389579 6677661
AND MBRIntersects(geometry, BuildMBR(389116,6677305,389579,6677661))"
This one takes only 2 seconds if spatial index table is available.
ogrinfo OSM_Finland.sqlite -sql "SELECT geometry, osm_id, highway,ref,
name, tunnel FROM osm_line WHERE highway IS NOT NULL AND ROWID IN
(SELECT pkid FROM idx_osm_line_GEOMETRY WHERE xmax > 389116
AND xmin < 389579 AND ymax > 6677305 AND ymin < 6677661)"
The Spatialite man Alessandro Furieri wrote this information:
"SpatiaLite isn't PostGIS: you *must* explicitly write
your SQL Queries in such a way to access the corresponding
Spatial Index table as appropriate.
Please note well: in SQLite/SpatiaLite the R*Tree
Spatial Index simply is another table between many
others.
The SQL engine has absolutely no idea that a strict
correlation exists between the "geometry" table and
the corresponding R*Tree.
So you are explicitly required to define an explicit
sub-query in order to inquiry the R*Tree."
Is the OGR Spatialite driver clever enough for making a conclusion
"If exists spatial index table 'idx_table_GEOMETRY' for layer 'table'
do use if when building bounding box filter"?
I found a blog posting about this thing and the author tells how
he could make SharpMap to render blisteringly fast from Spatialite
http://epsg27700.blogspot.com/2009/08/adventures-with-spatialite.html
I would not call my OpenStreetMap rendering from Spatialite with
Mapserver 6.0 (MS4W 3.0.3) blistering at the moment. The highway
layer takes more than 5 minutes to render even when zoomed very
close. The corresponding SQL query which is utilising the
idx_osm_line_GEOMETRY takes less than a second to run directly
through Spatialite-GUI so there is absolutely something to improve.
-Jukka Rahkonen-
