[gdal-dev] reading postgis raster in mode 2 error
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Mon Aug 29 06:15:22 EDT 2011
2011/8/26 Jorge Arévalo <jorge.arevalo at deimos-space.com>:
> ---------- Forwarded message ----------
> From: Ricardo Filipe Soares Garcia da <ricardo.garcia.silva at gmail.com>
> Date: Wed, Aug 24, 2011 at 6:07 PM
> Subject: reading postgis raster in mode 2 error
> To: gdal-dev at lists.osgeo.org
> Hi list
> I am trying out the postgis raster driver.
> I'm running Ubuntu 11.04 with gdal 1.8 from the ubuntugis repository.
> As for postgis I've compiled a snapshot of postgis 2.0 from svn, as
> offered on the postgis website.
> Following the directions in the driver info page[1], I've been trying
> to get a gdalinfo on the katrina.tif file. When I run it using
> mode='1' everything goes as expected and I get info on each of the
> tiles.
> but when using mode='2' I am getting this error:
> gdalinfo -mm -stats -checksum "PG:host='localhost' dbname='gis_testes'
> user='gisuser' password='resusig' table='katrina' mode='2'"
> ERROR 1: Error, the                     ONE_RASTER_PER_TABLE mode
> can't be applied if the raster                     rows don't have the
> same metadata for band 1
> gdalinfo failed - unable to open 'PG:host='localhost'
> dbname='gis_testes' user='test_user' password='test_pass'
> table='katrina' mode='2''.
> When importing the file into postgis I ran the following command:
> /usr/lib/postgresql/8.4/bin/raster2pgsql.py -r ~/Downloads/katrina.tif
> -t katrina -k 64x64 -o katrina.sql -s 4326 -I
> Thanks for your help
> [1] - http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
> ___________________________ ___ __
> Ricardo Garcia Silva
> Hi Ricardo,
> That error is caused because this query
> select (foo.md).* from (select distinct st_bandmetadata(rast, n) as md
> from katrina) as foo
> (being 'n' the band number).
> returns more than one result, and it shouldn't. Could you please
> execute that query in a client and send me back the results?
> Best regards, and sorry for the inconvenience
> Jorge Arévalo
> Internet & Mobility Division, DEIMOS
> http://es.linkedin.com/in/jorgearevalo80
> http://mobility.grupodeimos.com/
> http://gis4free.wordpress.com
> http://geohash.org/ezjqgrgzz0g
Hi Jorge, list
Running the query you suggest I get this output:
gis_testes=> select (foo.md).* from (select distinct
st_bandmetadata(rast, 1) as md from katrina) as foo;
 pixeltype | hasnodatavalue | nodatavalue  | isoutdb | path
 8BUI      | f              | -1.82132e-05 | f       |
 8BUI      | f              | -1.81834e-05 | f       |
 8BUI      | f              | -1.80478e-05 | f       |
 8BUI      | f              | -1.80471e-05 | f       |
(4 rows)
Can it be that the nodatavalue is messing things up, since it is not
the same for all the blocks?
