[gdal-dev] VPF support
Livneh Yehiyam yehil at rafael.co.il
Wed Aug 31 10:05:10 EDT 2011
Thank you for all the insight. I guess I will try to build 3.1.5 or take the precompiled from OSGeo4W.
Sent from my mobile
Subject: Re: [gdal-dev] VPF support
Date: 31 אוגוסט 2011 16:51
"Sommer, Martin" wrote:
> current OGDI sources (betas) need a bit of tweaking, if you want it to build yourself.
> Version 3.1.5 is far way better to build.
It's just an imprecise annotation, yet I'd like to share my findings
with you that the simple joy of getting an OGDI library built without
errors doesn't necessarily yield a working result.
Everybody who ever had a look at the VMap0 land cover data is familiar
with the 'usual' voids in northern Africa, middle east and Asia.  Yet,
when converting VMap0 into Shapefiles using the "3.2" version of OGDI
which is included in Linux Debian/AMD64, I've encountered many more
void areas then I was used to.
As a consequence I built OGDI 3.1.5 on 32 bit Linux in order to get the
familiar results.  I have to admit that I forgot wether the difference
was due to the OGDI version or some 32/64 bit mismatch.
Cheers,
        Martin.
 Unix _IS_ user friendly - it's just selective about who its friends are !
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
f
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110831/e642d125/attachment.html
