[gdal-dev] GDAL Ruby Bindings
Even Rouault even.rouault at mines-paris.org
Fri Dec 2 16:31:29 EST 2011
Le vendredi 02 décembre 2011 22:19:36, Ethan Alpert a écrit :
> Does anyone know if this made it into 1.8.1? The bug is closed but my
> ruby compile with swig 2.04 is still failing.
According to the comments in the ticket, this was pushed in the developement
version (1.9.0dev), but not backported in 1.8 branch.
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jim Klassen
> Sent: Thursday, March 17, 2011 8:21 AM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] GDAL Ruby Bindings
> This message has been archived. View the original item
> <https://cosev.digitalglobe.com/EnterpriseVault/ViewMessage.asp?VaultId=
> 1A1EA27771AEC4B4884E8701F0A6D75C11110000cosev.digitalglobe.com&SavesetId
> =204000000000000~201103171421260000~1~E6D07C89FD89426CAE8E6731D75C89B>
> I have updated the Ruby bindings so that they will build against Ruby
> 1.9 and the changes are in trunk.  I am looking for people to test and
> give me feedback.   If it works well for people, the changes may make it
> into a 1.8.x release.
> Details are available at the following URLs:
> http://trac.osgeo.org/gdal/wiki/GdalOgrInRuby
> http://trac.osgeo.org/gdal/ticket/3999
> Jim Klassen_______________________________________________
> gdal-dev mailing list
> This electronic communication and any attachments may contain confidential
> and proprietary information of DigitalGlobe, Inc. If you are not the
> intended recipient, or an agent or employee responsible for delivering
> this communication to the intended recipient, or if you have received this
> communication in error, please do not print, copy, retransmit, disseminate
> or otherwise use the information. Please indicate to the sender that you
> have received this communication in error, and delete the copy you
> received. DigitalGlobe reserves the right to monitor any electronic
> communication sent or received by its employees, agents or
> representatives.
