[gdal-dev] RE: Editing KML files using ogr_csharp.dll
Kyle Shannon KShannon at gcs-research.com
Mon Dec 5 10:54:15 EST 2011
Chris,
I don' know OGR very well, but I see a few issues.  I also am not sure about the c# bindings, I believe they are pretty complete though.
'''OSGeo.OGR.Driver drv = Ogr.GetDriverByName("KML");
DataSource ds = drv.Open("c:\\temp\\mykml.kml", 1);'''
Open() opens existing files, you need to use driver->CreateDatasource() to create datasets.  Open() opens files for editing.  If mykml.kml exists, use Open().
see http://gdal.org/ogr/ogr_apitut.html for information on using OGR to read/write data
'''Also, when creating a KML file from scratch is there a way to map the Name and Description fields to my existing fields so that the Name and Description appear in Google Earth?'''
See http://gdal.org/ogr/drv_kml.html for this, it appears to be possible.
There is also the libkml driver: http://gdal.org/ogr/drv_libkml.html
kss
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Pouliot, Christopher (DNR)
Sent: Monday, December 05, 2011 7:51 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Editing KML files using ogr_csharp.dll
Hello All,
I have a C# application that uses OGR_CSHARP.DLL to read/write KML files.  I'm able to read from KML files fine.  I'm able to create a new KML file and write to it fine.  I am unable, however, to open a KML file to edit.  I'd like to be able to append a new layer (folder) onto an existing KML file.  I've tried both of the following code snippets:
//This returns NULL
//This returns NULL
DataSource ds = Ogr.Open("c:\\temp\\mykml.kml", 1);
I'm able to use this code to edit File Geodatabases and Shapefiles but not KML.
Thanks,
Chris
Chris Pouliot
GIS Application Developer
Minnesota Department of Natural Resources
christopher.pouliot at state.mn.us<mailto:christopher.pouliot at state.mn.us>
(651) 259-5491
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111205/85e1e640/attachment.html
