[gdal-dev] build issue on OSX
Joaquim Luis jluis at ualg.pt
Tue Dec 13 19:48:36 EST 2011
It's been a while (well, a couple of months) since I built on OSX but I
only did a svn update and I now get these linking errors
....stall_name  /usr/local/lib/libgdal.1.dylib -compatibility_version 17
-current_version 17.0 -Wl,-single_module
ld: warning: path '/System/Library/Frameworks/Carbon.framework/Carbon'
following -L not a directory
Undefined symbols:
   "HFAEntry::FindChildren(char const*, char const*)", referenced from:
       _HFAGetIGEFilename in hfaopen.o
       _HFARenameReferences in hfaopen.o
      (maybe you meant: HFAEntry::FindChildren(char const*, char const*,
int))
ld: symbol(s) not found
Joaquim
