[gdal-dev] Inserting into PostGIS table with primary key using ogr2ogr
Luca Sigfrido Percich sigfrido at tiscali.it
Tue Dec 13 19:52:57 EST 2011
Thank you very much, Even. Apart from solving the problem, you're (as
always) opening new horizons to me :)
I'll test your solution tomorrow.
All the best!
Sig
Il giorno mar, 13/12/2011 alle 20.03 +0100, Even Rouault ha scritto:
> Le mardi 13 décembre 2011 14:47:40, Luca Sigfrido Percich a écrit :
> Yes, I've finally found how to do it without changing any line of code. Here
> come the power of the OGR VRT driver...
> 1) Fetch http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/ogr2vrt.py
> 2) Generate a templatpython ogr2vrt.py test_pk_data.shp test_pk_data.vrt
> 3) Edit test_pk_data.vrt to add a <FID> element that points to the ID column
> of your shapefile and remove/comment the <Field name="id"> element :
> <OGRVRTDataSource>
>   <OGRVRTLayer name="test_pk_data">
>     <SrcDataSource relativeToVRT="0"
> shared="1">test_pk_data.shp</SrcDataSource>
>     <SrcLayer>test_pk_data</SrcLayer>
>     <GeometryType>wkbPoint</GeometryType>
>     <LayerSRS>PROJCS[&quot;Monte_Mario_Italy_zone_1&quot;,GEOGCS[&quot;GCS_Monte
> Mario&quot;,DATUM[&quot;Monte_Mario&quot;,SPHEROID[&quot;International_1924&quot;,6378388,297]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;Degree&quot;,0.017453292519943295]],PROJECTION[&quot;Transverse_Mercator&quot;],PARAMETER[&quot;latitude_of_origin&quot;,0],PARAMETER[&quot;central_meridian&quot;,9],PARAMETER[&quot;scale_factor&quot;,0.9996],PARAMETER[&quot;false_easting&quot;,1500000],PARAMETER[&quot;false_northing&quot;,0],UNIT[&quot;Meter&quot;,1]]</LayerSRS>
>     <FID>id</FID>
>     <!--<Field name="id" type="Integer" src="id" width="10"/>-->
>     <Field name="name" type="String" src="name" width="50"/>
>   </OGRVRTLayer>
> </OGRVRTDataSource>
> 4) ogr2ogr -update -append pg:dbname=XXXX test_pk_data.vrt -preserve_fid
> Enjoy !
> I've also added a short comment about the -preserve_fid option in ogr2ogr
> manual.
> Even
