[gdal-dev] Newbie question about gdal_grid for 3d data
Brian Case rush at winkey.org
Wed Dec 14 10:50:33 EST 2011
Andreas,
There are no vector drivers for hdf and nc. take a look here
http://www.gdal.org/ogr/ogr_formats.html
As an alternative to gdal_grid you can use GMT's blockmean, blockmedian,
or blockmode. then use GMT's surface http://www.soest.hawaii.edu/gmt5/
On Wed, 2011-12-14 at 15:03 +0100, Andreas H. wrote:
> Hi again,
> another question which shows I'm just starting to see if GDAL can actually
> make my life easier :)
> I'm working with atmospheric trace gas profiles, so one data"point"
> consists of latitude, longitude (point or polygon, whichever is easier)
> and many vertical layers, say 60 floating point values. I ultimately want
> to create a global 1°x1° grid where all data"points" are put into and
> averaged.
> While I can see that gdal_grid will probably do the job, I cannot see a)
> how exactly and, more importantly, b) in which format I should prepare the
> input files. I'm preparing the data with some home-grown Python scripts,
> and I'm quite familiar with HDF and NC formats ...
> Thanks for your insight!
> Andreas.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
