[gdal-dev] Re: Slope in gdaldem
Stephen Mather mather.stephen at gmail.com
Thu Dec 15 22:31:41 EST 2011
Hmm.  I don't follow?  The revision would be this:
float GDALSlopeHydroAlg (float* afWin, float fDstNoDataValue, void* pData)
    // Hydrologic Slope is the max
    //  local slope btw center cell and adjacent cells
    const double radiansToDegrees = 180.0 / M_PI;
    GDALSlopeAlgData* psData = (GDALSlopeAlgData*)pData;
                double key;
    float pafLocalMin = afWin[0];
     float pafLocalMax = afWin[0];
    for ( int k = 1; k < 9; k++)
        if (afWin[k] < pafLocalMin)
            pafLocalMin=afWin[k];
        if (afWin[k] > pafLocalMax)
            pafLocalMax=afWin[k];
    key = afWin[4] - pafLocalMin;
    if (psData->slopeFormat == 1)
        return (float) (atan(sqrt(key) / (2*psData->scale)) *
radiansToDegrees);
    else
        return (float) (100*(sqrt(key) / (2*psData->scale)));
But, clearly I'm not understanding something about the window.
Steve
>>    if (key < 0)
>>        key = afWin[4] - pafLocalMax;
> Stephen
> 'key' can never be negative because pafLocalMin is computed from 'afWin'
> alone. The min val it can have is 0, when the minimum value is the central
> node itself.
> Joaquim
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111215/6219f8bf/attachment-0001.html
