[gdal-dev] Warping without shear
Joaquim Luis jluis at ualg.pt
Fri Dec 16 14:21:17 EST 2011
On 16-12-2011 18:50, Jan Hartmann wrote:
> On 16-12-2011 18:25, Joaquim Luis wrote:
>> Jan,
>> What you want is to apply a transformation called (at least on the
>> Matlab parlance) "Linear conformal" which an afine transform but
>> without the the shear terms. Mirone has it implemented and if your
>> image has the GCPS embedded the operation is really simple.
> Thanks Joaquim, that's exactly what I meant. How can I use Mirone's
> implementation?
See the manual for example at (the program comes with a .chm version
too). Expand the "Image->Register Image" entry
http://w3.ualg.pt/~jluis/mirone_/files/DrawGCPoints2.html
the above link is from an old-to-be-updated page. For program download
use w3.ualg.pt/~jluis/mirone
Joaquim
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111216/7c0e6c9b/attachment-0001.html
