[gdal-dev] Bug in GDALGetRasterSampleOverview
Sat Dec 17 10:51:35 EST 2011
On 11-12-17 04:38 AM, Marian Krivos wrote:
> Hello,
> current implementation of GDALGetRasterSampleOverview() don't work
> properly for big rasters
> over 2GB because of integer overflow.
Marian,
I mildly dispute this.  It is just that you can't express a desire to find
an overview with more than 2 billion pixels in it.  The raster itself can
be arbitrarily large.  I would claim it is not a common case at all to want
to do random sampling (this function primarily is used by
GDALGetRandomRasterSample()) of more than two billion samples and return it
in a simple array.  If you want very dense sampling you should be using some
sort of streaming process.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
