[gdal-dev] Re: error by starting gdal_merge.bat (win7, fwtools 2.4.7)
Jan Tappenbeck tappenbeck at widemann.de
Mon Dec 19 09:27:59 EST 2011
  hi !
thanks for answer.
but for OSGeo4W i only found the web-installer and our web-line is very
small so the installer died.
i did not found a downloadfile - can you help me again ?
reagards Jan  :-)
Am 19.12.2011 14:40, schrieb Chaitanya kumar CH:
> Jan,
> That package contains minimalist executables. It does not contain the
> pythin scripts. Use OSGeo4W to install it.
> On Mon, Dec 19, 2011 at 6:44 PM, Jan Tappenbeck <osm at tappenbeck.net
> <mailto:osm at tappenbeck.net>> wrote:
>     HI !
>     i download
>     http://download.osgeo.org/gdal/win32/1.6/gdalwin32exe160.zip - but
>     i did not found gdal_merge here ?
>     is this the wrong package ?
>     regards Jan :-)
>     Am 28.11.2011 18:53, schrieb Chaitanya kumar CH:
>         Jan,
>         A problem like this could be caused by any number of reasons.
>         FWTools-2.4.7 for windows is pretty outdated. It's better to
>         uninstall
>         it and use the binaries from OSGeo4W [1].
>         See if the error is resolved when using it.
>         [1]:
>         http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries#OSGeo4W
>         On Mon, Nov 28, 2011 at 9:25 PM, Jan Tappenbeck
>         <tappenbeck at widemann.de <mailto:tappenbeck at widemann.de>
>         <mailto:tappenbeck at widemann.de>>> wrote:
>              Hi !
>            i try to start a gdal_merge by win7 64 bit and the fwtools
>         2.4.7
>            gdal_merge.bat -ul_lr 2601660.7343  5477349.8203  2607572.5742
>              5475273.3574 -of GTiff -o %output%_number.tif %input%
>            but i get the message
>            C:\Program Files (x86)\FWTools2.4.7>echo off
>            Traceback (most recent call last):
>              File "C:\PROGRA~2\FWTOOL~1.7\bin\__gdal_merge.py", line
>         463, in ?
>                sys.exit(main())
>         433, in main
>                if quiet == 0 and verbose == 0:
>            UnboundLocalError: local variable 'quiet' referenced before
>         assignment
>            could everyone tell me the reason for this message ?
>            reagards Jan :-)
>            _________________________________________________
>            gdal-dev mailing list
>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>         <mailto:gdal-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/__mailman/listinfo/gdal-dev
>         <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
>         Best regards,
>         Chaitanya kumar CH.
>         +91-9494447584 <tel:%2B91-9494447584>
>         17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Freundliche Grüße
i.A. Jan Tappenbeck
Dipl. Vermessungsingenieur
CAD-Systemberater&  AutoCAD-Support
Widemann Systeme GmbH
CAD- und GIS-Systemhaus
Wiesbaden · Hamburg · München · Düsseldorf
Ackermannstraße 21, 22087 Hamburg
Fon: 040 / 229477-22
Fax: 040 / 229477-29
tappenbeck at widemann.de    www.widemann.de
Sitz der Gesellschaft: Wiesbaden, Amtsgericht Wiesbaden HRB 23345
Zu jedem Produkt das passende Forum unter http://www.widemann.de/wisysforen/
Widemann Systeme - aktuell:
geosi.DE - Vermessungssoftware ...
... für Straßenbau, Bauwesen, ....
- weitere Infos unter:
http://www.widemann.de/produkte/geoside/geosi.htm
Diese E-Mail enthält vertrauliche oder rechtlich geschützte Informationen.
Wenn Sie nicht der beabsichtigte Empfänger sind, informieren Sie bitte
sofort den Absender und löschen Sie diese E-Mail. Das unbefugte Kopieren
dieser E-Mail oder die unbefugte Weitergabe der enthaltenen Informationen
ist nicht gestattet.
The information contained in this message is confidential or protected by
law. If you are not the intended recipient, please contact the sender and
delete this message. Any unauthorised copying of this message or unauthorised
distribution of the information contained herein is prohibited.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111219/17f302ed/attachment-0001.html
