[gdal-dev] Re: WFS driver, ogrinfo and GetFeature
Even Rouault even.rouault at mines-paris.org
Mon Dec 19 11:11:53 EST 2011
> I am thinking as a WFS server admin and I cannot comment out the line
> from those who are possibly using our services with GDAL. I am  not
> causing so much trouble for myself :)
> I have set maxFeatures to 100000 on the server side. It will mean that the
> accurate extents method of gdal will calculate them for the first 100000
> features and with our layers which are spatially ordered the result will
> be much more wrong than if using and reprojecting the advertised extents.
> I would say that if WFS 1.1.0 server is answering for the first
> resulttype=hits query that there are 100000 features to come then ogrinfo
> should be able to know that it could be expensive to get them all with
> the next resulttype=features request.
> I have been thinking that WFS developers should never test anything
> against WFS feature types containing less than one million polygons.
> Testing against World boundaries does not show the whole picture.
Is your server available from the web ? If so, I could have a look on how the
advertized extent could be used. Ah, and what WFS server and which version of it
are you using ?
I'm thinking that we could try to use the advertized extent by default, and if
needed, the user could define an environment variable to have the extent
computed on all features. That way, the default behaviour would be more
reasonable.
