[gdal-dev] GDAL/OGR 1.9.0 Beta1 Released
Kyle Shannon ksshannon at gmail.com
Wed Dec 21 13:30:45 EST 2011
Even,
I rebuilt with GEOS support and I added podofo support as well, for fun.  I
got a failure with a bad checksum in pdf.py:
------------ Failures ------------
Script: ogr/ogr_gft.py
TEST: ogr_gft_write ... fail
Script: gdrivers/pdf.py
TEST: pdf_1 ... fail
line 164: bad checksum
Test Script: pyscripts/test_gdal_sieve.py
Succeeded: 2238
Failed: 2 (0 blew exceptions)
Skipped: 624
Expected fail:13
As GDAL_RUN_SLOW_TESTS environment variable is not defined, 20 "slow" tests
have been skipped
kss
 * Kyle Shannon
 * ksshannon at gmail.com
2011/12/21 Mateusz Łoskot <mateusz at loskot.net>
> On 20 December 2011 02:21, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Folks,
> > I have prepared a first cut for the 1.9.0 release (Beta 1).  Source code
> > and the autotest suite can be found at:
> >  http://download.osgeo.org/gdal/gdal190b1.zip
> I have built it and quickly tested command line tools in action
> using Visual Studio 2010, two configurations :
> nmake /f makefile.vc MSVC_VER=1600
> nmake /f makefile.vc MSVC_VER=1600 DEBUG=1
> for both, WIN32 and WIN64.
> All works for me.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111221/63a0b9f3/attachment.html
